There appears to be alot of confusion about when fog lights front/rear should be used.
Alot of people think you should put them on when its dark, or when its raining. In fact people tend to use them at every point apart from when they are actually intended.
They only truly make a difference on dark roads ie no street lights when your reduced to a crawl because you cant see 20ft infront. With main headlights on you just get a wall of light and can see bugger all. Switch just to side lights and fogs and you can generally see a bit more.
The muppets that use front and rear in heavy snow or rain need shooting though, as do those who just drive round with side lights and fogs.
Odly our Seat does the fog light on thing when you go round a corner, even if you dont have the fogs switched on! Why I dont know as it certainly doesnt help you see any better.
