hopefully some one can steer me in the right direction…..
my gears are working fine generally, shifts into all front rings and all rear rings except one..
it doesnt seem to like getting into 9th gear on the middle ring (3×9 setup).. it does seem to go in alot easier if i quick shift from say 7th to 9th in a continuous motion, but if im in 8th and try it takes a while to think about it and then goes in after a few more turns…..in bottom front ring and top, it shifts in fine…
then when im finally in that gear i get a catching noise coming from the front derailleur, ONLY in this gear, every other gear is silent and running fine, yet in that gear i get a constant catching (middle front ring, smallest back cog)…..
its not a massive problem as i can get into the gear, its just annoying and the sound of it catching is rather annoying too…
i know you adjust the middle ring by he barrel adjuster, but there is no/slight movement available either clock/anti wise so it doesnt do anything? im assuming its there that lies the problem, but why only that one gear catching?
any ideas?
