Ok so was running turbine front rings on an orange 5 24/32/42 wanted to swap the outer 42 for a bash as i keep bending them on rocks that just seem to jump out at me on norland moor.
Not a problem. ring off bash guard on. All worked fine….. then i messed with it.
I thought i could switch the shifter to 2 speed mode so i wouldn’t shift into the bash guard by accident. This didn’t really work. After an hour of adjusting limits it worked in a fashion but it just wasn’t quite right. Back to 3 speed mode and adjusting the top limit gave me the result i was after but i didn’t think that changing to the 2 speed shifter would cause such issues. Any ideas why?
Anyhow. Looking at the derailleur it is very close to the rear tire when on the inner ring. In my mind there is not enough mud clearance between the edge of the cage and the tire (2.2 trail king) can you get a shorter cage front derailleur? is there any disadvantage of this?
cheers,
