Viewing 13 posts - 1 through 13 (of 13 total)
  • Front crack ( whip ) noise
  • sheepshifter
    When fork takes hits every now and then a crack almost whip noise. Under close inspection the lower headset bearing rattles a tad do i have the wrong size could this be the cause, or is the steerer loose .
    ChunkyMTB
    Can you just try and nip up the preload a bit? That noise would usually mean a loose stack.
    sheepshifter
    Do that chunky, still makes a crack , push the bike into a wall with a small amount of gusto and a intermittent crack!!!
    ChunkyMTB
    Put a bit of grease in the cups and on the bearing.
    oldschool
    All the above, but loosen off the stem where it clamps to the forks before you nip up the top cap. Then tighten stem back up.
    (Apologies if I’m teaching you to suck eggs)
    benpinnick
    Pikes?
    sheepshifter
    Pikes they are , 120 mm travel .
    benpinnick
    They do that – its a creak in the CSU as you suspected. If they are less that 2 years old you can send them back for replacement / fixing.
    EDIT: I should say its probably a creaking CSU, but the sound is definitely more crack than creak so its very likely.
    Onzadog
    Humm, I’ve a set of pikes that do the same. Dangerous or just annoying?
    sheepshifter
    It is a crack like whip noise , thought it was my carbon bars failing.
    benpinnick
    Just annoying.
    Onzadog
    Wasn’t there a comment on here recently about curing it with a bearing retainer or similar?
    sheepshifter
    Replaced fork with fresh grease and the bottom bearing rattles , when preloaded wheel push ed into an obstacle the bottom bearing moves . New bottom cup etc I’m hoping will be the cure .
The topic ‘Front crack ( whip ) noise’ is closed to new replies.
