“Three bloody quid…!!!”
When thats added up over everyone else, just think how far that could go into trail maintenence and trail extension/additions?
“Chip piece of pad away putting front wheel in.
£20 for new pads”
Was the chip so bad that it reduced the size of the pad significantly? Could you have not used it anyway? even for one ride? For it to ‘chip off’ it probably wasn’t bedded in well enough to start with
£20 gets you 4 pairs from superstar
“keeps leaking out when unscrewing pump”
Usually its the air depressurising from the shock that makes the noise/pressure loss. When you connect the pump to the shock, the pressure in the shock/pump pipe has to equalise so shows a lower reading than the shock was when you pumped it last/before you connected the pump. Mine is about 15 psi difference
[It could be its leaking in use too]
“Gears all out of sync. Bent hanger”
You could try bend it back? The mech should give you some leverage?
Otherwise, you should have carried a spare hanger, like you bike manual might (the giant one did when I read it once) tell you to carry one
Or you could’ve tries to live with out of sync gears for the rest of the ride
“Should have stayed at home”
You said it
