You can case harden it by soaking it in a urea bath. Just cover the surface in stale urine and let it soak all afternoon. The nitrogen atoms from the urine will be absorbed into the crystal matrix and form a hard surface. If you can’t source enough urine, guano is a perfectly acceptable substitute.
This is complete nonsense, there is no such thing as case hardening concrete. You can cure it by covering it in damp hessian (as mentioned by slowoldman) or using a spray applied curing membrane. You can treat dusting concrete with Lithurin (spelling similar to urine, but completely different chemical).
Adding urine or guano will have no benefit, somebody is having a laugh 😆
If you don’t believe me ask The Concrete Society http://www.concrete.org.uk/contact-us.asp
