My rear mech keeps freezing up when it gets really cold. It’s on a Canyon Strive, SRAM x0 shifter and mech. The cables are internally routed but there’s no outer cable inside the frame (there’s a ferrule at the entry point into the frame, then a plastic stopper where it exits. I can change from the small gears to the larger ones, as I’m tensioning the cable, but when I go the other way the spring isn’t strong enough to make the shift happen, even though the shifter is releasing the tension on the cable. I can make it move by hand though. It doesn’t happen on the front so not sure if it has anything at all to do with the cable routing. Also the cable is brand new, teflon coated. Any ideas what I can do to stop it happening, starting to get on my nerves now.
Oh and by the way, when I get it back to the house in the warm, it works absolutely fine within an hour or so.
