A reply I gave on a similar thread
Although Brierly hill is a C/D transmitter & all the digi stuff pretty much falls in that band
http://www.ukfree.tv/txdetail.php?a=SO916856
I'll have a go at explaining why some people can only get some channels & why there seems to be a need for a 'digital' aerial
UHF bands IV & V are used for UK terrestrial TV 471MHz to 847MHz [give or take]
These bands are split into channels & given numbers 21-68
Before all this digital malarkey, when we had 5 channels – they had to try & stop adjacent transmitters interfering with each other so they grouped the channels & made sure that adjacent main transmitters used different groups & different channel number within them
Group A – Ch 21-37
Group B – Ch 35-53
Group C/D – Ch 48-68
there are others but I'm ignoring them as irrelevant
Aerials were made to tightly adhere to these groups – so if you were in a group A area you'd have a group A aerial fitted etc.
with me so far ?
OK – along comes digital & a lot of transmitters didn't have the room to fit in the digital multiplexes within it's group so they simply put some of them out of group meaning a lot of the aerials rejected the signal & created the need for a wide-band aerial in a lot of areas
What was often the result was that the aerial would pick up some of the muxes that had been kept in [or close to] group but rejected the others or have some that are marginal & pixelate
Pretty much every area is going to be different so a universal solution is impossible other than make sure you have a suitable aerial.
Hence was born the myth of the digital aerial – all it is, is a wide band [group W] UHF aerial [/b]
