Here's some stuff neither I nor my mates need, far too knackered to sell but useable enough not to throw away. Postage by gifty/no fees paypal and they are yours. My paypal address is the same as my profile email.
Specialized BG comp mtb shoes size 45, a couple of versions old and as you can see very very tatty! The right one far more than the left, sole is juuuuust starting to lift off the heel and I have repaired a rip and the ratchet mount with a needle and rot-resistant thread. No cleats but still useable if you just want to try out clipless pedals. Standard parcels is £4.41.
Bikehut carbon riser bar, 31.8 clamp, 630mm wide, medium rise. Little metal reinforcing grommets for bar ends or lockons (only ever used 'normal' rubber grips on them though).
Somehow the use of correct torque settings and carbon assembly paste has left the very shallow yet perfect impression of the stem clamp in the lacquer, along with quite a few scratches and a couple of 'bubbles' in the lacquer. They don't creak or owt, just that mrs julian wanted wider bars and I already have a couple of other wider sets in a box for a rainy day so can't see myself ever using these. Silly light but too long to post as a small packet, so standard parcels charge of £4.41 gets you these in a handelbar box.
