20" frame and forks, ok condition for age. Comes with stem and threaded headset. Stem is a bit surface rusty, headset is probably ok, will need a regrease though.
Here's the rub. The seatpost is stuck fast. It's a ritchey type which i've had in the vice to try and turn but has ripped part of it off.
Also the bb, a sqare taper catridge is also stuck. I had a metre long pole on the spanner today and it wouldn't budge.
Options then will involve heat to remove the bb and poss the seatpost, but if you can get the bb out you can eat the seatpost out with caustic.
Shame really as it's a half decent frame, but i've not got the time or equipment to sort it.
If someone wants it, it can be collected from glasgow, or i ca box it up and you can sort a courier if you like.
If it doesn't go it'll be scrap.
Nikjohnson(at)btinternet(dot)com
