slight hijack, but what do people think of the sub- or micro-compact chainsets that might start to become more popular
eg: Praxis Alba https://www.praxiscycles.com/product/alba-m30/
which would then enable people to access lower gearing for the big climbing sportives but then keep a closer range cassette for their ‘normal’ rides, without needing to bodge MTB cassettes or worry about cage lengths, etc.
Big day – put 11-32 on
Normal – run 11-28
You lose the 50-11 top gear (4.55) but your top on the sub-compact (48-11 = 4.36) is higher than second top 50-12 = 4.16 on a compact, and frankly the only time I’m not shitting myself spinning out in 50-12 is when it’s on Zwift.
I know the purists will sneer, as they did at compacts, and I know that proper riders are now also starting to go to mid-compacts at 52:36 because they’re so butch, but i rarely remember a ride when I’ve felt that having lower gears has actively disadvantaged me, I just haven’t used them on some rides.
edit – FSA are doing a 46-30 even……
http://www.fullspeedahead.com/fsa-super-compact-cranks/
