Singletrack – 97.5er full suspension
Hey guys this is brilliant 🙂 I just found this by researching what my bike might look like with the project that I have planned. I have been spending a lot of my recent weeks thinking about geometry, handling and performance good and bad concerned with various wheel sizes, factoring skinny and wider tyres on varying size wheels. I find it fascinating, so I decided after making my first 96er (old type mountain bike with 26 back wheel and a road bike wheel on the front). That it may be time to get a full suspension bike as a 96er out of some left over parts that I have but would still need to buy more.
So I just recently bought these items:
Dt Swiss XMM 29 forks, carbon steerer and crown with twin shot remote lockout. It’s a two stage lockout, can lock out fully or partly by restricting the rebound mechanism and thereby reducing the fork travel from 120mm – 80mm. Good for racing 🙂
Trek scratch 9 2010 – downhill / free ride frame with 170mm travel and also fits a 650b nobby Nic 2.35 tyre.The nobby Nic runs at 706.5mm, which leaves 4.7mm clearance from the frame axle to top of yoke. This measures 358mm from the arch to the centre of the axle, the chain stays has slightly more clearance at 362mm. The shock is fox rp2 with pro-pedal and the only bad thing about this frame is that it weighs 3.5 kg.
The trek was bought with a 26 back wheel in mind with the 29er front end, then I realised that people are using these frames as enduro bikes with 650b wheels. So after measuring and researching and also doing a bit of maths I came to the above conclusions of numbers.
These are the other things that I have:
700mm carbon low riser bar.
60mm 7050 grade alloy stem.
Alloy seat post
Carbon saddle or old flite selle Italia, leather with padding and weighs 295g
Xx1 cranks or sworks carbon mountain cranks, with 32 or 36t rings that I currently have.
Xx1 rear dérailleur
Kms x10 chains and one X11 Kms chain.
Foam grips or rubber type.
Stans no tubes solution and rim tape.
So I need to organise more parts to finish the bike, but it’s a good start. I aim to finish the bike off with a final weight of around 12kg, or 26.4 lb.
This is using carbon rims of 390g 30mm wide, which are not cheap and will take me some time to get it going.
Tyres – nobby Nic 27.5 x 2.35 rear and 29 x 2.35 front (or 2.25 x 29 I’m not sure yet).
Valves for running no tubes.
Cassette xx1
Gear cables – alloy outers and friction coated inners.
Refurbish the hope headset – needs new bearings.
Xx1 gear shifter.
7075 alloy hydraulic brakes single Pistons with 180mm front disc and 160 rear.
Egg beater pedals.
I need to source the other items to make the bike
