Having a bit of a clear out and am selling the following items:
All prices include postage. More pictures of everything here http://s891.photobucket.com/albums/ac113/andrewh8877/Items%20for%20sale/
2010 Dirty Jo Full-Crème aluminium hardtail frame. 17”. I am 5’11” and this is just about the smallest frame I can get away with, not recommended for anyone taller than me. It is DJ’s posher version which has the triple butted tubes and weighs in at 3½LBs, excellent for a frame at this price. It takes a standard 1 1/8” headset and 27.2mm seatpost. It has V-brake and International Standard disc-brake mounts. I have used it as a singlespeed with a tensioner in place of the rear mech so it has less cable rub than would usually be expected as it had fewer cables. It does have it’s fair share of scuffs and scratches of course. I have drilled a couple of the cable guides to allow me to neatly zip-tie the rear brake hoses.
Any downsides? Only one, there is one cup from a bottom bracket still in it as my big spanner has gone walkies and I need that to get it out.
£95.
Maxlight rigid forks. Standard 1 1/8” steerer tube, cut to 190mm, nice mix of imperial and foreign units there. It has standard 9mm dropouts for quick release axles. 17” axel-crown. It has International Standard disc mounts and will take V-brakes if you can find some studs for it. Usual scuffs and scratches but nothing major.
£30.
Very rare Rondelli F1TT time-trial frame and Time Chrono carbon forks with Ritchey WCS headset. Not sure of the year but early 2000s at a guess. Frame number is 10004. Bit of a funny size, the centre of the BB to the centre of the seat tube is only 49cm but I am 5’11” and rode it for two years. The top tube is 52cm c-c. This is just about the smallest frame I can get away with, not recommended for anyone taller than me. The chainstays are carbon fibre and it has the funny shaped seat tube to reduce drag from the rear wheel. The forks are Time Chrono and have plenty of steerer showing to allow you to get the height for the bars you want. The headset is a Ritchey WCS, which is their top-end one, or was a few years ago. New Scott Plasma forces sale
£145
Built with Mavic wheels, 9 speed Dura-Ace and Cinelli Angel bars
FSA Vision aero/time-trial/triathlon handlebars. These come with a 90mm FSA Vision stem, standard 1 1/8”. They are in pretty good nick, couple of scratches but not much. The pads are in very good condition. They have internal cable-routing for both brakes and shifters. The extensions are 250mm. Brand new ones are going for over £180 on Fleabay http://www.ebay.co.uk/itm/FSA-Vision-Team-Trimax-Flat-Bar-Racing-Bend-/200624804831?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item2eb62b93df and that’s without the stem! These are yours for £99.
SKS AirExpress track pump. Good working order, couple of scratches, has a gauge and the head takes shrader or presta without needing to swap anything around. Pumps up to 140PSI but the new tubs on my time-trial bike take 180PSI so I’ve had to get a new pump. £15
BRAND NEW Fibrax brake pads for Hope Mini Mono. Semi-metallic (organic) Still sealed in the original pack. £6.
Shimano Dura-Ace aerobar front two speed shifter. Couple of scratches but otherwise excellent. RRP for a pair is about £70 so £20 for this one sounds about right.
BRAND NEW Shimano Dura-Ace lockring, CS-7700, fits 12t smallest sprocket. £5.
BRAND NEW Token TK161 seat clamp. Really light. 34.9mm (used with a 31.6mm seat post if that helps) RRP is about £15, sell for £9.
BRAND NEW Unbranded seatclamp. 34.9mm (used with a 31.6mm seat post if that helps) £5.
Valve adapter for time-trial bike’s disc wheels, brass. Fits the shrader bit of the pump and presta on the tyre. £5.
Raceface AirAlloy handelbar. 23”, standard clamp size. £15
Talon Engineering TCR105 granny ring. 5 bolt , 24teeth. Excellent condition. Very rare. £10.
Talon Engineering TCR107 big ring 5 bolt, 42 teeth. Had a little use but still works perfectly with a brand new chain. Smoothest shifting ever. Very rare. £15.
Two no name steel flat bars. One black, one silver. £5 each .
Open to offers, especially if you want more than one item.
I’m in South Lincolnshire if anyone wants to collect rather than have it posted. If you want it posted paypal gift please.
andy_howett at yahoo.co.uk
