DIY is fine as long as its given long enough to harden off. (6-weeks). It is bloody hard work. I’ve done a couple & the best results were with Plasti-Kote, not Halfords knacker-lacquer.
But it wont be anywhere near as durable as powder coating. Frame will need stripping to bare alloy to powder coat. Also crucial to ensure any mounting surfaces/threads are kept clean. Cured powder is very difficult to remove, & even if masked off I’d factor in getting the b/b threads run through by your LBS, along with disc mounts faced. A good powder coaters will have high-temp masking tape to keep areas clean, but a general insustrial coaters will be unlikely to want to faff about. Heat is also a factor, I wouldnt bake an alloy frame above 200c as it could affect the heat treatment. A good, experienced powder coaters will know about this stuff anyway.
You could rub down to give a nice key, & get a local car body shop to paint it with two-pack. Obviously your tied to what colours they have, & two-pack paint is very expensive to buy. In theory two-pack should be less likely to crack as its not as thick as powder coat.
You could always strip & polish it…
