If it is just the swing arm it might fit in a domestic oven. the temperatures for heat treating aluminium should be easily achievable AIUI. Got to be worth a go.
I’m hearing what everyone is saying, but what i really want to hear is ‘get a new frame bro, new frame, new frame, NEW FRAME, NEW FRAME’
Looking at postage costs, repair costs, price is close to total frame value. I just don’t think i’d ever be happy but seems a waste not to at least try.
Have you spoken to Transition? Replacing parts will often make more sense even if there’s a cost (my Hemlock frame was made entirely out of replacement parts!)
If you want recommendations for frame repair welding then probably orange 224 owners are the best resource. They’ll tell you how bombproof and reliable the frames are, then they’ll tell you who welded up the cracks for them. 😆 (ok more seriously, if you’ve got an uplift venue locally, and a shop that caters well for them, they may have some good advice)
Good thinking Northwind, just emailed windwave and fingers crossed they have a swingarm. Really like the frame so keeping it going is the preferred option.
Specialized road frame MY2002, lovely stiff light aluminium frame, after 6 years I found a crack forming from a air (frame casting? Don’t know much about aluminium tubing production) hole at the rear of the drive side seat stay. With nothing to lose, I gave it to the welder father-in-law who passed it on to an alloy specialist welder at his work to have a go at fixing it NB the crack had not yet gone all the way round.
Got it back like this with a comment ‘it went better than expected’ ie he didn’t completely destroy it even though the tubing was so thin.
I used it for a bit of time trialling and to be fair it cracked at a different weld after another year; the repair held ok. I suspect with a MTB and it having cracked through already, YMM considerably V. Bad luck.
Heat treating performs 2 functions – a stress-relieving, post-welding, but it will now be relatively soft. Many then need to be tempered – heated to 1000 degrees and quenched – to give them the strength. Keeping components aligned is also very important!
I’ve never known an aluminium repair work very well and that bit will be under quite a lot of cyclic stress. But it probably won’t hurt you badly when it breaks again 🙂
1000 deg for aluminium! Don’t think so.
A little bit on heat treatment of Columbus tubes here.
Sooo, Being a curious type, I’ve continued to do a bit of reading.
It looks like the 2nd heat treatment after soaking is to accelerate age hardening. It depends on the specific alloy, but apparently, age hardening at room temperature can take as little as 5-30 days, but in the case of 6000 series alloys often used in bikes, this is a process that can continue for years.
