- This topic has 131 replies, 47 voices, and was last updated 7 years ago by hainman.
Fox X2 Recall
deviantFree Member
That shock with the 7 spacers is ridiculous….i made a post on here a few years ago now where i stated that if a shock is needing the buyer to retro-fit spacers to get it working properly then its probably not fit for purpose and should go back to the manufacturer or at the least off to a specialist to be properly tuned….
….needless to say i was criticied for it and told how i was a neanderthal and how tuning with spacers was the best thing since sliced bread etc etc….
Amatuers with no clue about suspension tuning should leave well alone and i include myself in there, i’ve always used TF-tuned but other firms are available.
I’ve seen too many well intentioned idiots out on the trail with too much air in the shock or as in the case pictured above too many spacers…it goes without saying that the shock doesnt work and the bike rides like crap….instead of going back to the beginning and buying a shock with the correct tune or sending their existing one off for tuning they add yet more air or spacers!MTBers seem to love a good tinkering but suspension is one of the dark arts that even fully paid up pros in motorsport often get confounded by…but your average MTBer seems to think he/she is a tuning god because RS and Fox have given them the ability to bung a load of crap in there in an attempt to get it working close to properly….i dont get it?!?!
My weight often fluctuates between 12st and 15st depending on what time of year it is, what other sports i’m doing at the time, whether i’m lifting weights or not etc…but i’ve never felt the need to take apart my suspension or add spacers and so forth, i set the sag anywhere from 20%-30% depending on what kind of ride i’ll be doing and how plush i want it and then i ride…never bottomed it out, blasted through the travel or any other problems i often hear about and i’ve used RS, Fox and X-Fusion in recent years with the same good results….my riding has been in the fairly flat South East and laterly rocky and mountainous Wales, what exactly are poeple doing that they need to add 7 spacers to what should be a premium shock?!
Rant over but that pic of the X2 with 7 spacers is everything thats wrong with MTBing at the moment…bizarre.
chrishc777Free MemberTo be fair it doesn’t look like there is actually any room left for air in that air can!
2/10 for the rant by the way, no improper use of capitals, not enough exclamation marks and the spelling seems good.
Hob-NobFree MemberThat shock with the 7 spacers is ridiculous….i made a post on here a few years ago now where i stated that if a shock is needing the buyer to retro-fit spacers to get it working properly then its probably not fit for purpose and should go back to the manufacturer or at the least off to a specialist to be properly tuned….
Congratulations, 99% of your post is absolute guff.
poahFree Memberdeviant – Member
deviant – Member
Amatuers with no clue about suspension tuning should leave well alone and i include myself in thereindeed
bluearsedflyFree MemberI had a call last Friday from Giant to say the ’17 Reign Advanced I was interested in had been delayed well into the new year. Which comes with an X2. Probably 2+2=5.
Luckily I’d already gone for a different bike.
chrishc777Free MemberHaha was wondering how long before those started cropping up
duirFree MemberInteresting point Deviant. My X2 was custom tuned by mojo for my Nicolai Geometron the bike Chris Porter designed and it came with 4 spacers fitted.
maxtorqueFull MemberPicture clearly shows a failure of the can, starting by the stress raiser point near the machined valve housing/buldge. If you want to mitigate against this failure, put a few layers of decent gaffa tape around the can and then two nic ebig jubile clips, which will then just result in a safer release of air pressure, but prevent the can “unwrapping” and flying off……..
If you even work to industrial pressure vessel standards, you’ll know how weedy by comparison the thin, turned alluminium air can of most air shocks is. Considering that above 10bar, you would need to meet basic pressure vessel design standards for an industrial product, it’s actually a little suprising on how bike air shocks can be made so weedy! However, because the compressed volume is small, the total energy release is pretty small too.
simondbarnesFull Membersurely the best thing for fox to do would of been to put out a press release with the solution. not just dont ride the shock and wait for an announcement.
What makes you think they have a solution yet?
honourablegeorgeFull MemberHob Nob – Member
Was “i dont get it?!?!” the 1% ?
rickonFree MemberWhat makes you think they have a solution yet?
Well, the later 2017 models aren’t in the recall. So worst case for Fox is to replace old with new. Whether they can manufacture fast enough is to be seen.
The best outcome for them would be to have a retro-fix. They do need to do something quick and seamless if they want to maintain customer trust, of they balls it up like Samsung, they’re gonna lose a big chunk of market to Rockshox and the challenger companies.
alsoranFree MemberAre the models with the climb switch as standard effected as all these are advertised as 2017 models???
honourablegeorgeFull MemberI suspect the fix will be a combination of a new air can and the red limiter below, I think that’s a new thing
yongeyFree MemberI agree with maxtorque’s theory. Split line is in the longitudinal direction which sees the highest stress. I would also suggest that people running higher pressures and more volume reducing spacers will have a greater likelihood of failure occurring since that combo will see the highest pressure rise through the shock stroke.
As for the rant about user tuning of shocks…..behave. Fully optimising shocks is far from easy, but there’s plenty of guidance out there to make adjustments to suit ones preferences. So long as you follow the guidance and stay within limits (I.e. Don’t fit millions of volume reducers) it’s all good as far as I can tell.
honourablegeorgeFull MemberApprently the 2017 version has both the red limited above and a small allen bolt to keep the air can sleeve in place.
sofaboy73Free MemberApprently the 2017 version has both the red limited above and a small allen bolt to keep the air can sleeve in place.
not the early 2017 ones – mine hasn’t
TrimixFree MemberOK, given all the above and the fact I don’t have spacers and run it at about 190 psi and don’t huck to flat from the roof of my house…..I shall ride mine till there is a replacement available.
honourablegeorgeFull Membersofaboy73 – Member
Yeah – some bloke on pinkbike says he had one warrantied and got one with an Allen Bolt for the can – other 2017 cans don’t have this.
BELIEVE NOONE
TraceyFull MemberJust had a mail from Tribe in France. They have attached a press release from Fox with regard to this
sofaboy73Free Membersofaboy73 – Member
BELIEVE NOONE
must be the fix they’ve instigated following the faults on the 2016 and early 2017 models. I notice they’ve also dropped the max recommended psi down from 300 to 250
RickDraperFree MemberThey have also cut back quite on the amount of spacers you can run. 63mm/2.5″ stroke shocks are now 3 spacers max, iirc it was 5 max before.
honourablegeorgeFull MemberYeah, think mine has 4 in it, Mojo set it up originally, and there’s a fifth in the box I was tempted to put in.
sofaboy73Free MemberThey have also cut back quite on the amount of spacers you can run. 63mm/2.5″ stroke shocks are now 3 spacers max, iirc it was 5 max before.
think it depends on if they are the old black rubber spacers or the orange plastic clip on ones. if the latter, mojo advised me you can run more and my 215×64 came with 5 fitted as standard with 7 being the maximum
timmysFull Member2017 50 mm stroke. Three orange spacers fitted (of 4 max). 240 psi
Better not cycle near any children’s faces.
think it depends on if they are the old black rubber spacers or the orange plastic clip on ones. if the latter, mojo advised me you can run more and my 215×64 came with 5 fitted as standard with 7 being the maximumTheir chart shows different values for 2.5″ and 63mm now, which is pretty baffling
RickDraperFree Member^ it shows different amounts for a old shock measurements and a metric shocks, Fox USA never classed the 2.5″ shock as a 63mm stroke shock. The 62.5mm shock will have a different dimensions to the similar sized 8.5×2.5 shock.
57.5, 60 and 62.5mm shocks all share the same chassis as the 65mm stroke shock, that’s why those 3 can take more volume spacers as the stroke is restricted via a internal spacer. Just the same as a 7.275″ eye to eye X2 uses the same chassis for 2″ and 2.25″ stroke but the 2″ one can use more spacers.
TrimixFree MemberOne day the US might join the rest of the world and use the metric system.
chrishc777Free MemberThink pretty much every review said the 36 and X2 are the best. The only negative comments were on price.
Yes there is an issue, but they are sort of dealing with it and the cause has yet to be revealed. Could well be that only ones with too many spacers have failed
In the meantime RS have continued selling shoddy seatposts whose seals blow, and forks with CSU issues.
We demand top performance, low weight and perfect reliability, there will be issues with some products
sofaboy73Free MemberTheir chart shows different values for 2.5″ and 63mm now, which is pretty baffling
hmm, might just drop a spacer or two out then to be on the safe side until there is some form of resolution to the problem.
rickonFree MemberThink pretty much every review said the 36 and X2 are the best
Having used a lot of the latest offerings for Fox and RS, I’d agree with that. The 36 is definitely stiffer than the Pike, it’s a bit better overall on damping. It’s not quite as plush on small bumps, but more controlled.
Fox and Mojo have always been great at sorting things out for me in the past, so I’m confident they’ll sort out the X2 issues.
simons_nicolai-ukFree MemberThe X2 215×64 mojo sent me (unaltered) had 4 orange spacers in (and another 4 in the box – not enough space to physically fit that many in the shock).
Doesn’t seem very consistent.
chrishc777Free MemberAnyone heard any news on this? Are they recalling them yet? Have they actually done anything for the hundreds of riders they’ve told to stop riding their bikes?
NorthwindFull MemberRick Draper – Member
They’d better be ready to refund everyone that uses 4 or 5 spacers then I guess.
Bizarre to me that people would blame users for adding spacers (as long as they remain within spec). That’s like having a dial that goes from 1-10, and if you set it to 10 it breaks, then saying “well obviously 10 is a big number so you shouldn’t have used it. Volume tuning spacers are just inconvenient adjusters.
Does explain why I can’t get through to mojo to order the 36 parts I want 😆
eazyd74Free MemberYT just emailed me telling me not to ride my Capra. They are waiting for further details regarding the recall.
Hob-NobFree MemberI managed to survive the weekend racing on mine, and it didn’t go bang.
otsdrFree MemberIs there anyone that doesn’t use spacers? If everyone needs a smaller volume, what is the point of the large air can?
I managed to survive the weekend racing on mine, and it didn’t go bang.I was also not killed.
The topic ‘Fox X2 Recall’ is closed to new replies.
