Querying something I was told in Evans Cycles. The guy in the shop told me that I should only ride the shocks on the “firm” setting when climbing. He said to leave it on in the flat sections would damage the pistons. Is this true? Frankly as I like to ride hard on the flats & plan to use the bike doing XC I would like to ride it often on the firm setting.
I checked the Fox website & I couldn’t find any advice that would back up what the store guy told me.
The shocks on the bike (Trek Fuel Ex 9.8) are:
Front suspensionFox Performance 34 Float, FIT4 3-position damper, E2 tapered steerer, Boost110, G2 Geometry w/51mm offset, 120mm travel
Rear suspensionFox Performance Float EVOL, RE:aktiv 3-position damper, tuned by Trek Suspension Lab, 7.25×1.875″
Thanks!!
