Had my Fox 36’s serviced & a spendy cartridge upgrade earlier this year.
They got well used at Les Arcs,rode the bike a couple of times over here since & on compression the right fork has started to make a strange noise so I want to take them apart & see what’s going on.
Question is,If it’s just something loose can I get away with re-using the seals why I go for a test ride or do you have to replace the seals EVERY time you remove the lowers?
I’ll be fitting new seals as soon as I’m sure I’ve fixed the noise problem.
Thanks in advance
