Viewing 3 posts - 1 through 3 (of 3 total)
  • fox float travel adjustment help
  • mrlard
    right i got a set of 2009 140mm travel floats
    my question to you all is if i reduce the travel will this reduce overall height of the fork.
    the reason i ask is i have a frame and 140mm travel is just to much so was thinking to un-slacken 😕 the geometry a bit i could shorten the forks.
    your thoughts?
    mrlard
    right after not receiving an instant response I got bored and tried it it effects the lot!
    Rorschach
    Learn by doing….so time well spent (all time fiddling with bikes is well spent) 😀
The topic ‘fox float travel adjustment help’ is closed to new replies.
