Fitted new low friction seals to my 36’s on friday. It’s an easy enough job to do if you follow the links previously suggested. Allthough i do recommend you change the oil, what was left in mine was filthy!(barely 4 months since last change). I just clamp the bike in the stand, loosen lower nuts then knock with rubber mallet and allow oil to drain into drip pan. Once i have removed lowers and done all work as shown in mojo’s video i then turn bike upside down to fill with new oil. Everything seemed very plush today with first ride out around cwmcarn, just had to back-off the rebound damping a little.
