Bear with my newbie question pls 🙂
I’ve 2014 Fox float forks and shock on my bike (Canyon Spectral) and am thinking of adding a CTD remote lever to the bars.
I’m starting to use descend mode more and more as I gain confidence/skills to push harder/faster downhill. Trying to switch between trail and descend on the fly by leaning down and altering the CTD levers on the fork/shock whilst riding is a sure fire way for me to end up crashing, hence I’ve left it in trail mode most of the time so far, but really like the feel of the descend mode (which I find really confidence-inspiring) and want to use it more.
I can only add remote CTD capability to my forks, as my Fox float rear shock is not CTD remote upgradable.
My idea was to leave the rear shock set in trail mode all the time and be able to alternate the CTD forks between climb/trail/descend as needed using the remote on the bars.
question – I’m guessing that having the forks running ‘softer’ than the rear shock isn’t a problem and that varying the fork’s CTD settings alone, is probably far better than just leaving both forks and rear shock set in trail mode all the time?
Views, advice?
