Viewing 2 posts - 1 through 2 (of 2 total)
  • Fox 36 Talas – no rebound damping!
  • nowthen
    Hi All,
    I have a 2013 Fox 36 Talas 180mm with FIT cartridge, it seems that the rebound damping has disappeared completely (the rebound dial has no effect, from full on to full off), although the High/Low compression still seems to be working fine.
    I am assuming that the FIT cartridge is damaged or needs servicing, but could there be any other simpler cause? The FIT cartridges look like a complete nightmare to service at home…
    Thanks
    nowthen
    LoCo
    Service, it’s likely to be a small clip that’s causing the issue.
The topic ‘Fox 36 Talas – no rebound damping!’ is closed to new replies.
