Fox 32s @ On-One
[Closed] Fox 32s @ On-One
[#1638309]
Fox 32s @ On-One, every one might know about these and those that don't I am not sure I should be telling! I was just having a look to see how the carbon frames are coming along (just looking...) and see a link to these....
http://www.on-one.co.uk/i/q/FOFOFOX32/fox-32-float-140-rl-suspension-forks-
F32 RL for £299.99 - !!!
Posted : 24/05/2010 3:32 pm
People have mentioned them before, but they don't suit the current trend which has gone away from traditional 9mm axles.
Posted : 24/05/2010 3:34 pm
 tron
They don't come with shock pumps you know. It's a scandal! Nearly wipes out the £400 saving off RRP 😆
Posted : 24/05/2010 3:40 pm
Shit!!!
You mean if I bought those and fitted them to a bike I wouldn’t actually be “on trend”? Christ how could they sell such products the chancing gits….
Posted : 24/05/2010 3:47 pm
Exactly! And obviously you wouldn't be forced to buy a new front wheel too 😉
Posted : 24/05/2010 3:49 pm
Well we can’t have that...
I’ll get some Mavericks instead; I like my forks expensive, unreliable and with the axle as non-standard as possible…
Posted : 24/05/2010 3:55 pm
and you can fit spacers to take the travel down to 120mm or 100mm travel so they fit frames designed for 'just riding around' too. It's a disgrace I tell you.
Posted : 24/05/2010 3:57 pm
Edit...
Is the travel adjust straight forward?
Posted : 24/05/2010 4:11 pm
travel can be adjusted easy peasy, you dont need to send em to mojo or tf or whoever, just need to put some spacers in the leg (im sure theres a how to on tinternet somewhere) and fannys your aunt or uncle 😉
Posted : 24/05/2010 4:15 pm
[url= http://www.mojostore.co.uk/acatalog/Forx_Travel_Spacers.html ]http://www.mojostore.co.uk/acatalog/Forx_Travel_Spacers.html[/url]
there's a 'how to' on their site too. you can perm any combination of spacers as well, which is nice.
Posted : 24/05/2010 4:17 pm
 nbt
£300 for the 15mmQR 120mm floats @ CRC
Posted : 24/05/2010 4:19 pm
They are the F120 Rs, not float RLs though
Posted : 24/05/2010 5:51 pm
 nbt
True, but 20mm travel is not that much difference, and personally I never use lockout so a simpler fork with less to go wrong is more appealing. And they're bolt through.
Posted : 24/05/2010 5:55 pm
Lockout an travel aside, the F-series and Float are totaly different forks though. The F-series is the lightweight xc version and I read somewhere that you can't adjust the travel with internal spacers like you can on the float.
Posted : 24/05/2010 6:07 pm
 nbt
Ah right, wasn't aware of that. Cheers for the info.
Posted : 24/05/2010 6:38 pm
And haven't they got a tapered steerer at CRC?
Posted : 24/05/2010 6:40 pm
No - that's a bargain
Posted : 24/05/2010 6:42 pm
its not actually a 9mm QR its a standard QR
if you have compatible hubs; dt, spesh, halo, some bonty, hope
you can get a 9mm thru axle to beef up stiffness
Posted : 24/05/2010 6:43 pm
Got some along with a 456 for £450 can not go wrong with that
Posted : 24/05/2010 6:45 pm
