Have you ever felt the 32s lacking in the past? James is spot on, the Pikes are fairly basic so they’re stiff but less controlled, your 32s will be much less stiff but possibly more controlled (depending on the model) And with the capability of a Pitch you’re more likely to run into issues with either or both of those.
I really don’t like 32s at anything past about 120mm, they’re very obviously an XC fork with delusions of grandeur but at the same time, I don’t like turnkey dampers much either. If it was me, I’d try it with the 32s as you already have them and then if that doesn’t work out upgrade. But I would not buy these 327s.
BTW there is no Pike that has no compression damper- the 327 comes with the basic turnkey compression damper which lacks adjustment
