I ran 160mm 36 floats on my Voltage FR this year.. I didn’t feel like I couldn’t charge just as hard as I would on the same bike with 36 van (yes, I tried both)
Having spent the best part of 3 seasons (1 was XC racing), trail riding and AM riding a Ransom with 36 Talas in Whistler/Squamish finest, I wouldn’t be afraid to run that as my every day fork – f you wanted to be a 1 fork guy.
Dont forget that if going to 36, you’ll probably be needing a new hub (or adapted if you’ve already switched out the oem wheelset) as 36 takes a 110/20mm thru where as the 32 you have is likely 100/15mm.
But, if you’ve the inclination to have a holiday/uplift fork.. Float or Van.. either will work nicely.
