Soooo new bike. Never had to adjust Fox 15mm axle forks before.
The Fox manuals of recent years are useless i.e. Just warranty and cautions in several languages.
So the retainer with small allen bolt is fair bot loose once axle removed.
When axle is installed, lots of thread (which I assume should be inside leg dropout) showing.
I cannot make out what all those numbers are actually there for where you can supposedly slide round then nip up retention bolt.
Oh btw, the lever is in correct position.
I’m 99.9% sure this is a simple thing but my mind boggles with the retention bolt and number notches.
Could someone point me in direction of some instructions with pics so my simpleton mind can put 1&1 together.
Either that or tell me!
