Lol plan A would be all nuclear, the renewables are just to appease the rest
A full nuclear solution isn’t the ‘magic wand’ solution either…nuclear tends to operate best at base load (a relatively flat output 24/7/365). Although I understand that the next generation of nuclears, commissioning from 2024/25 will have some flexibility but not in any way appropriate for the extremes of UK national demand.
Comparing the UK to the US doesn’t help – their operational models differ dramatically to the UK and their seasonal demand trends do not compare well to the UK either.
UK Winter Peak tends to be 52-55GW (52000MW-55000MW). UK Summer minimum demand has got as low as 17GW/18GW in the last couple of years due to a combination of recession, energy efficiency and the amount of embedded generation i.e. local wind / solar PV reducing demand (from National Grids perspective).
By the end of the decade National Grid forecast ‘summer lows’ to trough somewhere nearer to 5GW at certain times of the day as the amount of distributed generation continues to increase …
…this will cause significant grid-operational issues as (a) one day could look extremely different to the next as weather (and therefore renewable generation output) changes, meaning grid will still need conventional, despatchable generation, connected and available ‘in their back pockets’ and (b) the MW demand may be significantly less than the ‘must run’ generation MW i.e. on a sunny breezy day we may have 10/15GW of Solar PV, a similar amount of wind and 10/12GW of base load nuclear…too much generation – requiring novel solutions to rebalance the equation.
