I used the superstar kevlars in oros, they were spot on (alps trips, downhill racing- nobody in the history of biking ever braked as long or as hard as I did racing the fort william endurance dh on my trailbike 😉 ) Certainly no lack of power. The kevlar hoses were probably a waste of money sadly, most oros used a braided hose as standard.
You do have to bear in mind it’s an 8 year old design, and I think the last ones made were in about 2010, but even so they are imo a better brake than Strokers, comparable on power with more feel. I upgraded mine to The Ones and yep there’s a fair performance gap, but there should be!
So… Either they are broken, or set up wrong. And frankly most things that would rob them of all their power would also have other noticable side effects- leaks or drag. They’re not the most intuitive to bleed- by which I mean, I’m a pretty good diy spanner and I bled them how I wanted to rather than as the instructions said, and that didn’t work out 😉 Then I followed the instructions, and it all went swimmingly.
Whereabouts are you? If you’re Edinburgh-ish you could come over and I can take a look…
