consider myself ok at bleeding them, but cant seem to get this one right. lever seems to have too much play before biting, and as im pootling along on the flat, the pads are 'singing'. i put a bit of pressure on lever and it stops, let go the lever and it soon starts again. i could keep riding forever with just a slight bit of pressure on the lever and itd be fine. let go and it sings.
id say i can get the lever to halfway before it feels like its biting the brake.
so…….not really sure why, but thought a bleed might cure it. did it as per usual. pushed pistons back, 'push me pull you' for a few times, then cable tied the lever to close reservoir, and pulled from both ends to get rid of any individual air bubbles. then released lever, 'push me pull you' a few more times, no bubbles apparant, jobs a good un.
but……..lever still seemed to be halfway or so before biting, and yes, pads started singing again. so i havent really made it any better, just bled it for nowt really.
anyone got a reason why this should happen? im thinking air would make it spongy, so its not that. its as though theres not enough fluid in maybe, and the lever is taking up dead space when i start to close it? so theres no pressure on pads and theyre vibrating? just a wild guess tho.
thanks for any suggestions.
