Viewing 2 posts - 1 through 2 (of 2 total)
  • Forks “topping out”???
  • Purplefunkymonkey
    Got a set of Marz XC600 that give a knock when the weight is taken off the front end *topping out* , is this normal or are they buggered??
    da funk
    davidtaylforth
    How fast is your rebound? Try adding a bit more rebound damping.
    I often found adding a touch more oil to the legs or adding slightly heavier oil prevented top out, not sure whether your forks are the open bath style marzocchis though
The topic ‘Forks “topping out”???’ is closed to new replies.
