first i have to declare i have done lots of swpping bits about etc.
they started as solo air Sektor RLs but now have dual pos coil spring and Rebaound damper labelled as for U-turn coil sektors. Compression damper is original standard MoCo.
the noise is like that creaky noise you might get in your knees, low-mid frequency. not trebley.
the u-turn rebound damper is the most likely culprit as it seems to be on extension it make the noise, or more so anyway. had a posher dual-flow rebound in just before and they were fine, but added top-out spring meant i wasn’t getting full travel.
so sounds liek i’ve just talked myself into a diagnosis of rebound damper. but it was brand new and i can’t really see any reason whay all those bits shouldn’t play nicely together.
possibly oil volume?
