I have an RL2 on a bird zero (waves at Ben). I find it great for most things, it’s soft when I want it to be, but I’ve never had it bottom out harshly. It coped well on an uplift day, my arms weren’t pumped buy the end of it. The only things that aren’t great is it can be a bit divey when braking (only really notice when it’s steep, I’ve touched the ground with the chain ring when things have gotten too steep and rough for me). And I had a couple of issues with the axle handle (first it was too floppy, buy I worked out how to fix it, then it jammed ‘out’so I couldn’t put it in the fork. Bird sorted it out in no time and I didn’t miss a ride.
I recently tried a couple of demo bikes with pikes. If I was buying a new bike or fork, it would be looking for an x fusion fork unless there was a very good reason not to.
Ben, do you know if the rough cut damper is available separately, yet?
