It will certainly change the geometry but whether you feel the difference and whether its for the better or not depends on how sensitive you are to geom changes and the frames current geom.
For example jambalaya says he doesn’t feel mush difference between 120mm and 150mm where as on an old bike I used to have with 120mm to 150mm U turn Revelation forks I could feel a big difference between the two extremes, It was noticeable straight away which setting I had the fork on.
An extra 20mm on fork travel is towards the upper limit of whats sensible. You’ll slacken the head angle by around 1 degree and raise the BB by a bit too.
