I think you’ll definitely need to narrow things down a bit. There’s a big range in headset stack heights now, depending on what sort of headset your frame needs (of course what headset type you need can depend on the fork steerer type too). Get some sort of handle on that, and what stem you want to run. Add them together, add a bit, then cross your fingers you’ve worked it out OK
The very lowest stem height you’ll get is 30-35mm, normal stack closer to 40mm. Headsets likely to be in the range of 20-35mm. Plus a few spacers for fit/luck. So you’re looking more at steerer plus 80mm, maybe more.
