Keep the pressures the same. All that happens of you put more in the bottom (Negative air) is that it drags the fork down slightly and the pressures equalize anyway
There’s a bit of a knack to setting them up. It’s easy to end up with more -ve pressure and drag the fork down –
Let the -ve air out, set the +ve pressure then reset the -ve to the same psi or a little LESS if you like, which makes the fork feel a bit more progressive (Even coil-like) IMO.
Just to shake things up a bit 🙂 I think they feel better with more negative pressure than positive, even if you do ‘lose’ 2 or 3 mm of travel.
Set up this way, they feel like the best of both worlds – coil suppleness and linearity through the mid-stroke with a nice ramp up towards bottom out.
