Many thanks for that Andyl. Would you believe that I believed typing “fork oil” into the CRC search tool would turn up trumps! Silly me!
I ordered the two weights of oil last night. Should be with me tomorrow if usual service is anything to go by. In anticipation I pulled the forks apart tonight.
Findings:
Lowers came off fairly easily. I was led to believe from the service manual that there should be some oil in each of leg lowers. Seems that either a few months of light use has “used” all the oil or that there was never any in there from day one. The insides are so dry i cannot believe there has ever been any oil within a country mile of these forks. There will be tommorow.
Spring came out simply also. Looks to be well greased and no water in there as i feared there might be. Not happy with the stiffness of the pre-load dial.
The damper had oil in and looked to be clean with no emulsified mess in. I put this back together straight away.
So far nothing to be afraid off. Is there any top tips that are not in the manual?
Cheers in advance
