Viewing 20 posts - 1 through 20 (of 20 total)
  • Fork grease
  • Dickyboy
    Got a a families worth of forks to service & wondering what proprietry grease I can get in a decent sized tub, rather than spending oodles on those miniature pots & tubes that cycle shops sell. Thanks
    z1ppy
    Silkolene RG2 Grease from your local motorcycle shop, not paricularly mega cheap but good stuff
    Dickyboy
    Thanks, is that Silkolene RG2 defo okay for fork seals?
    nuke
    Del
    or stendec fork grease…
    Scienceofficer
    apart from seals, I didn't think that many forks actually used grease these days.
    Dickyboy
    Scienceofficer – I think you'll find that because I tend to buy things cheap just after they go out of fashion but before they become retro, then most of my forks will need plenty of grease.. 😳
    missingfrontallobe
    Manitou do tubes of M-prep fork grease, my local Go-Outdoors usually stock it.
    TandemJeremy
    Any old grease will do then IMO Big tub of castrol LM.
    If there is no damping oil then all the seals do is keep the dirt out
    Onzadog
    I love the silkolene RG2 but I wouldn't put it near the insides of any forks. I've got a tube of M-Prep, some Pace stuff and some old Judy butter. All in reasonable sized packets and all lasting well. If anything, the Judy butter is lasting too well as the name might suggest.
    Scienceofficer
    LOL dickyboy!
    andymonty
    No LM grease will cause seal swell (assuming by LM your referring to Lithium grease)
    TandemJeremy
    If the forks don't have damping oil in them but are just greased springs then it will only be dust seals so will it matter?
    Onzadog
    There's often a lot of plastic parts in forks like that. Some plastics and some greases don't mix well. I think that's the main reason the suspension specific stuff came about.
    TandemJeremy
    Ah – point taken onzadog
    jasonm945
    What about Moly Grease or paste, reason I suggest this is because Moly is what is used in spring powered air rifles, which is a plastic (or leather) seal that slides down a steel tube, same principle but opposite?
    Jay
    Dickyboy
    All as clear as daylight then? Doesn't really help knowing that at least two of the pairs of forks I am servicing are oil damped in one leg only…. looks like I might have to buy the tiny expensive pots afterall. The Magura Ronins service require equivalent to one pot of judy butter – ie 15ml per leg, so you can see why I would have liked to have found a cheaper option.
    Dickyboy
    Looks like Stendec fork grease will be the best bet £9 for 150ml should do a few forks (as opposed to £5 – £12 for 29ml of Judy Butter!) cheers Del
    schrickvr6
    Get some Rock n Roll Super Slick grease, it's designed for forks.
    jasonm945
    Look here!
    Jay
The topic ‘Fork grease’ is closed to new replies.
