I stripped down my 2007 Fox Van R’s to give them a bit of pre-alps service the other night and the foam wiper on the spring side, and the oil in that leg, we’re both filthy grey/black.
The stanchion on that side has some quite bad wear consistent with the bushing rubbing but that hasn’t caused it to leaked in the past, and they have only been ridden for 5/6 dry days in the Alps since the seals, foam rings and oil were last changed so I was a little surprised at how dirty it was…the other leg is fine.
Do you think the contamination is likely to be dirt/dust ingress or the consequence of further wear to the bushing/stanchion?
Anyway, given all of the above would you…
A. Clean, change the oil, put it back together and hope it all lasts another week in the Alps. Possibly with Enduro seals.
B. Attempt a repair of the stanchion with some metal epoxy, hope it lasts the Alps.
C. Buy some new forks.
Interested to hear people’s thoughts, thanks.
