Helicopter tapes a bit of an eye sore , would like something black ideally . Also everything’s running smooth so i don’t wanna be shortening cables an re routing .
Well make your mind up about which is the bigger problem, rubbing, an eyesore (clear tape?) or a bit of faff re-routing.
Didn’t know if there was a neoprene cover or similar about .
Chances are, if it still makes contact it’ll rub through it, whatever the material, Heli-tape is the best option and can be re-applied if it does get damaged, but really, correct cable routing and length is the answer.
Adding tape/covers etc. is a workaround for a problem that shouldn’t exist, crowns* don’t need protecting because a cable shouldn’t rub on them!
* plenty of other places will/do rub, but a fork crown shouldn’t be one of them.
