Thought I’d try here as there’s a few Mondeo owners on here. I know it’s a long shot but here goes….
Picked up a cheap 05 Mondeo hatch yesterday for the wife but hadn’t spotted that the front passenger door EXTERIOR handle is not working consistently (works about half the time).
Having had a quick peak inside the door and at the mechanism it seems that everything is working properly EXCEPT that the rod that releases the lock could do with adjusting as there’s a fair bit of movement.
It’s obviously adjusted by the door handle at the top of the door but I can’t work out how to release and/or move the adjuster clip up/down the threaded bit. The rod itself doesn’t turn.
I could remove everything from the car (handle / lock etc) but can’t believe this is what’s needed.
Help gratefully received.
