Restoring a Cunningham (or any bar aluminum frame) that has seen the worst of the elements involves a two step process.
#1 apply Fluid Film, a corrosion/protectant with #8447 or #7447 Scotch Brite pads. In the case of this frame, this step was repeated 3 times. Buff with a clean terry cloth rag after each application.
#2 apply a liquid wax, Nu-Finish in this case, with a #7445 Scotch Brite Pad. This further protects the frame. Buff with a clean terry cloth rag after the wax is on for a bit.
whats the deal with the welds on the top/down tube are they seam welded gussets?
Yes I think they are seam welded gussets. The frames are incredibly light though.
Cunninghams are a bit like Vermeers, the whereabouts of every frame Charlie built is known. The chances of a tiny bike shop in Point Reyes having three in the stands at one time is pretty rare.
