Viewing 2 posts - 1 through 2 (of 2 total)
  • FloatRP23 weep – service?.
  • Olly
    Afternoon!.
    My FloatRP23 shock weeped when it was new. (came on a new frame)
    I left it alone, as i know new shocks sometimes do for a bit while they
    bed in. Its a year later and its still doing it!!
    enough to collect dirt and grit around the base of the shaft within an hour of riding(snigger)
    Is it likely that a seal change will sort it, or is indicative of a bigger issue?
    Is a RP23 seal change easy enough to do? (ive opened one up for an oil change and done forks before)
    gmanfox
    there is a small amount of float fluid the migrates out of the dust wiper which is normal any more then it has probably got a seal gone inside and you will need the nitrogen tools to re charge it my company http://www.southcoastsuspension.co.uk is only charging £79 with free postage this month
The topic ‘FloatRP23 weep – service?.’ is closed to new replies.
