Viewing 17 posts - 1 through 17 (of 17 total)
  • Floating rotors & Elixirs
  • rocketman
    Am idly contemplating some Superstar/Hope/Clarks etc floating rotors but I understand the carrier can sometimes foul on the caliper/pads
    Just wondered if anyone had used Elixirs with floating rotors?
    majorspaniel
    Yes, I’m using hope floating rotors with avid elixir cr’s, iv had no issues.
    hrcmonty
    I’ve also got SS Floating rotors,
    180/160 and using their adaptors. I actually get no fouling with my CR’s that i’ve just put on. My Tektros did though big time!
    rocketman
    OK thanks fellas. I must admit the Elixir calipers look fairly minimal and it’s hard to imagine how a floating rotor could mess them up but you never know eh?
    I’m still haunted by J3s & RT76s
    khani
    Hope V2 floating rotors don’t foul the caliper as they have a deeper braking surface than standard floating rotors, but they only come in 180-203…
    rocketman
    Thanks for that some 203s are what I need want
    xiphon
    Aren’t Hope V2s thicker than other rotors, so aren’t compatible with other calipers.
    philstone
    I tried Hope floating on my Elixir 5’s and they did catch..
    Grim
    I have Shimano 180 & 160 floating rotors with my elixr 5s. They do not rub!
    Grim
    khani
    Those are vented, you can get non vented V2 floating rotors as well, I’ve got some on some oro bianco’s and they work a treat
    I tried standard mono mini floating rotors and the rivits fouled the calipers on my oro’s
    KevinPP
    Isn’t it more down to the hub/fork combo? Running Elixirs and Hope floaters on both bikes with no probs.
    adam_h
    Elixir 5’s and Hope floating rotors here with no rubbing.
    xiphon
    Ahhhh I thought V2s were all vented (hence the ‘V’ bit…)
    redafro
    what type of hope floaters are you folks using, the V2’s or the saw tooth..
    I’m wanting to get some 203F and 183R with me Elixir R’s.. Running DT swiss hubs with and Fox Talas 32’s. Anyone running this setup and have and rub issues??
    GolfChick
    does anybody know if the superstar floating rotors will catch on formula rx’s?
    Onzadog
    My wife is running juicy 5 with hope 183/160 sawtooth hope rotors. I just cut the tang off the pads. No more catching.
    njee20
    I had the Saw Tooth Hope Pro ones on Elixirs, they were fine.
The topic ‘Floating rotors & Elixirs’ is closed to new replies.
