I would like to add some clip on tri bars to my flat handled commuter bike because I’m planning on doing a 200km ride in a couple of weeks.
My current problem is that clip on tri bars don’t fit because my flat bars are “oversized” at the stem and then taper down to a narrower width at the end. They are 31.8mm in the middle and the taper starts pretty quickly so I can’t clip on the tri bars. I considered wrapping the bar in tape but I’m not sure that will be particularly safe if they start coming loose when I’m blasting down a road.
Does anyone know of a solution which would work? Is there a flat bar which is less tapered or should I think about replacing the stem so that’s it’s got a smaller diameter bar mount? Links to something compatible would be hugely appreciated.
