Viewing 40 posts - 1 through 40 (of 146 total)
  • Fix this laptop?
  • Cougar
    A work colleague brought a friend’s laptop to me yesterday for me to have a look at. I’ve fixed it now, but it was an interesting problem, so I thought you lot might like a punt at diagnosing it.
    Symptoms are, every few minutes Explorer shuts down leaving just the desktop (no icons, no task bar). You can restart Explorer from Task Manager (File / Run Task / Explorer), it comes back up normally and is fine for a few minutes before closing again.
    If you want to play along, ask me questions and see if you can diagnose the fault. I’ll be as honest as I can, but will be a “user” and not volunteer information you don’t ask for.
    What do we do with it?
    IA
    Anything in the startup items folder in the start menu?
    Reply, “ooh, tricky, i can have a look – would you fetch me a coffee and a donut?”
    bails
    Hello Mister,
    I am calling from your bank. To protect your security please confirm your credit card number, PIN and mother’s maiden name.
    Thanking you.
    Trailseeker
    If some media players don’t get a response from what they are asked to play, they can cause Explorer to restart & you’ll loose taskbar etc whilst this happens.
    Is it a corrupt media file?
    Cougar
    Nope.
    It’s not playing media. It happens continually.
    beej
    Corruption in the registry? Something wrong with explorer.exe?
    What OS, version and build?
    glenh
    Needs switching off and then back on again.
    bigyinn
    Multiple AV programs installed?
    perchypanther
    Did you try turning it off and then on again?
    Edit : Bollocks! 30 seconds too slow.
    hot_fiat
    have you installed anything like winzip, winrar or a new anti virus program recently?
    Milkie
    What version of windows?
    What services & programs are running?
    When did it start happening?
    I’ll go with Malware for the moment, or a corrupt dll..
    sfc /scannow should fix a corrupt dll
    molgrips
    Anything in the windows event logs?
    clintthesquint
    PICNIC
    Problem In Chair Not In Computer
    leffeboy
    I would be looking in the logs for something not responding
    Turn off windows search
    Run a disk check
    Unplug all peripherals in case it is choking on something external
    But, is there some sort of add on like winzip, c cleaner appearing in the right click menu?
    Oh, and is the problem every few minutes when it is idle or when you are working?
    Cougar
    Dunno, how would we check that?
    Good question. It’s Windows 7 Home Pro, x64. Didn’t check the build.
    Webroot is installed, no other AV.
    Not to my knowledge. I asked what had changed recently and was told “nothing” in a user-y fashion.
    Various things, what are you looking for?
    I’ll go with Malware for the moment.
    What do we do about that then?
    Another good question. Nope.
    Cougar
    I didn’t think to do that, but it’s not relevant here.
    Run a disk check
    Good. Chkdsk finds no problems.
    Only thing attached is keyboard and mouse.
    I can’t remember exactly but probably not. Nothing that raised suspicion, anyway.
    Both.
    hot_fiat
    Did your coputer update itself reently? Did windows update run, or did your anti virus software suggest any application should be updated?
    molgrips
    Does it do it in safe mode too?
    Are the intervals very regular?
    molgrips
    Tried SFC?
    woody2000
    What brand/model of laptop is it?
    Cougar
    It’s not had a Windows Update in a while as far as I can see. The AV hasn’t reported anything for a while either.
    No.
    It seems to be pretty regular, yes. You can’t work on it for more than a few minutes without it happening.
    trail_rat
    despite it being suggested twice already . inkeeping with what my it department do when ever you progress through the levels of ” i cant fix this heres my supervisor”
    have you tried turning it off and back on again 😀
    Milkie
    At this point, I would probably do what you are doing and ask for the laptop, there are too many services and processes to check which a glance can quickly see if there are any abnormal things running. 😉
    Still interested in the solution though!
    Did sfc /scannow fix a corrupt dll?
    Cougar
    Tried SFC?
    Good. SFC reports no issues.
    disco_stu
    Are there any local security policies setup? Does it have the same problem with a different user?
    Cougar
    It was an Acer that looked like it’d had a hard life, I don’t remember the exact model though.
    Nothing jumped out as being obviously abnormal.
    Milkie
    What do we do about that then?[/quote]
    If it’s malware, I would probably download a bootable virus/malware checker and let that run. Sometimes I find it quicker to just re-install the system than spending hours trying to find the problem, some malware can be long-winded to remove.
    molgrips
    No.
    So it’s not explorer itself at fault, it’s a driver or something that happens regularly.
    I’d be timing it. If it’s very regular then it’s some job that’s set to happen on a regular basis that is crapping out.
    What’s in the startup programs list? Post a list? Or just tell me if it’s not one of them.
    Cougar
    Ooh, interesting thinking. I didn’t check secpol, but I’ll say “no.” There was only one user account and it didn’t occur to me to create another to see, but I’d expect it would still be symptomatic.
    BaronVonP7
    Is it supplied by Plusnet? (who’ll “do you in proud?”) – If so you’ll never find out what’s wrong with it and the only solution is to move country.
    Is there a scheduled task or app trying to shutdown the ‘puter?
    Is the battery/power supply ok – no flames or billowing smoke?
    woody2000
    Fan exhausts full of crap? Heat bad 🙂
    beej
    Install the latest display drivers.
    Has that fixed it?
    perchypanther
    Have you whacked it really hard with your elbow?
    Always worked for the Fonz.
    BaronVonP7
    … resource exhaustion? (Disk Full).
    joshvegas
    Have you hoovered the keyboard?
    Cougar
    Malwarebytes was already installed at the advice of the colleague who brought it to me. It found “a couple of things” but I’ve no idea whether these were problems or false positives.
    It’s every five minutes.
    I did a selective startup via msconfig, disabling all non-MS services. Still symptomatic.
    rossendalelemming
    run msconfig and disable everything in the startup.
    reboot.
    working?
    if so, enable one at a time until it breaks 🙂
    BaronVonP7
    Does it still occur if you disable all network adaptors?
    Is there any removable media inserted? SD card, CD etc.
    Cougar
    We have a winner! Though, credit should also go to Molgrips who was on the same lines. I thought that would take a lot longer, curses. (-: Here’s the first part of the story:
    In Scheduled Tasks there was an oddly named task, “vyi” or something. This task was scheduled to run every five minutes, and executed c:\ch.vbs. ch.vbs is a one-liner script which launches c:\ch.bat. ch.bat is another one-liner, TASKKILLing Explorer.exe.
    The next question is… how / why?
    JackHammer
    Petty virus?
The topic ‘Fix this laptop?’ is closed to new replies.
