Viewing 13 posts - 1 through 13 (of 13 total)
  • Fitting new headset – to grease or not to grease? That is the question
  • bjj.andy.w
    As above really. Looked on the park tools website and there’s no mention of greasing the cups before insertion
    nedrapier
    not
    lovewookie
    very small amount.
    It’s not like ye olde square taper where you have the danger (albeit not that scary) of damaging the crank by it sliding too far up the taper*. The cups go in until they’re done, a little bit of grease helps them go in and also acts as a barrier to corrosion between the frame and the cups for a little while anyway.
    *that discussion is not really needed here is it…
    prezet
    Yep. Can’t do any harm.
    trail_rat
    “Can’t do any harm. “
    based on what ?
    matt500
    I did, i also stuck the cups in the freezer overnight which helped.
    prezet
    based on what ?
    Well, the bike is hardly likely to fall apart is it. 🙄
    It’ll at least help the cup insertion, and prevent possible future seizure when trying to remove.
    trail_rat
    if your doing it to prevent seizure then you want anti seize or copperslip – even better would be light loctite.
    grease is to aid movement – sliding componants , seals and bearings.
    never had an issue putting them in dry , you dont want to encourage movement in press fit or cause creaking by introducing an agent for dirt and dust to stick to
    TandemJeremy
    I grease any metal to metal contact unless using copaslip or locktite. Never ever a dry joint
    lovewookie – Member
    very small amount.
    Actually you should grease square taper cranks IMO
    explanation cortesy of sheldonbrown
    http://sheldonbrown.com/brandt/installing-cranks.html
    BrickMan
    +1 on anti-seize (that white/grey stuff).
    As I’ve ripped paint of many frames when coming to remove them (cup grabs paint during its years on the bike, then when hammered out of frame, grabs it behind and flakes off = corrosion = bsrt£!!!d to get another one back in).
    xcstu
    Dry on dry.. never… Grease/Copperslip most def 🙂
    bjj.andy.w
    Thanks for the replies, cups are in the freezer as I write and I’ll put some copper slip on them before insertion. Cheers people 8)
    Junkyard
    yes agree for non moving parts use copper slip grease to prevent seizing as one day you may wish to remove them.
The topic ‘Fitting new headset – to grease or not to grease? That is the question’ is closed to new replies.
