Viewing 6 posts - 1 through 6 (of 6 total)
  • Fitting new bush/mounting kit – Fox rear shock
  • tartanscarf
    Help!
    I've just bought the bits plus the tool to replace the fixings on my rear shock. The instruction here http://www.tftunedshox.com/files/shock_bush_removal_fitting.pdf shows this specifically for the 'rebound adjustment' end of the shock but is the process the same for the other end?
    This is probably a daft question but I want to make sure I'm right before proceeding.
    TS
    peachos
    from my experience there's not usually a 'hoola hoop' type bushing to replace at the other end, just the mounting kit which should be ok.
    tartanscarf
    Sorry, I should have been clearer. My main concern is in using the tool to push the bushing out at the other end. Is that correct?
    Three_Fish
    It's the same both ends. The holes are the same size.
    tartanscarf
    Tremendous <gets vice back out>.
    tartanscarf
    Fixed – woo hoo!
    Cheers folks
    TS
The topic ‘Fitting new bush/mounting kit – Fox rear shock’ is closed to new replies.
