Hi there, wondered if anyone has done this recently? It’s an old ish alloy hardtail frame I’ve got with no disc mounts. Built it up on the cheap as a multi purpose bike – mostly using it for some commuting, but also on the local pump track from time to time.
Currently running hs33 maguras but the back one isn’t brilliant, and one of the brake bosses on my forks is a little bit bodged.
I’ve ordered a rear disc brake retro fit mount which I’m waiting to arrive at the moment. Made by tensile it bolts onto the drop out and has a torque bar to the brake boss.
http://www.tensile.net/uploads/8/7/2/4/8724844/s203431135453455303_p4_i1_w1025.jpeg
Has anyone used one of these before – any comments on ease of fitment?
Assuming it fits ok and I can get a disc brake to line up ok (got a 6 bolt disc rear hub) then I’m thinking about getting some Clarks M2’s just because they are so cheap and I don’t need anything special (got guide RS on my fs bike, but they are expensive to buy). Just 160mm discs – and hopefully they will bolt up ok. Got an is mount fork – think it’s either a 98 or 99 Bomber z1 bam. Anyone uses the Clarkes M2’s?
