No, got to be honest, not even sure if a 29er would fit. Every inch higher under the bed makes it about half an inch shorter at that point of the van!
I’m not set on a dropper, but when I saw the Brand X CX dropper in 27.2mm for £90 I thought it would be rude not to.
I’m afraid the magura is a bit spendy (and its not 27.2mm). I could go for an external routed post, wife has a gravity dropper and it only takes a moment to pull enough slack through the cable guides to get the post out of the frame…but you have to pull through almost all of the spare cable at the bars.
I have a non-remote gravity dropper that I swap between two mountain bikes, but its an ugly old thing to have on a new bike and its fairly sloppy…can’t see any other 27.2mm externally routed posts.
To be honest, at the moment I can’t think of a way of releasing the cable without pushing outer cable into the frame!
Maybe I should just slightly file my brand new frame so the outer runs a bit smoother…hmmmmm
