And I’ve just dropped it off at the bikeshop to be built.
Its not going to be light but built to last for me and hopefully virtually indestructible 🙂
Hoping for around 33lbs which most people will scoff at until you compare it to my body weight then its positively feather weight 🙂
[url=https://flic.kr/p/q5GmeT]Nicolai Ion 650B[/url] by ianpindir, on Flickr
[url=https://flic.kr/p/p98aQt]Nicolai Ion 650B[/url] by ianpindir, on Flickr
It’s an Ion 16 650b in XL, with a heavier tube set and different levers so it can run a 222x70mm shock providing 150mm of rear wheel travel. The geometry is custom, angles are similar but it’s got a shortened seat tube by 75mm (I think can’t remember the exact reduction) with a 24.5inch tt.
BOS Deville AM 160mm 650b
Bos Kirk 222×70
Chris King BB
Chris King Headset
Chris King Hubs on Mavic EX 821 650b Rims
Schwalbe Hans Dampf tires
Shimano XTR Shifters
Shimano SLX Front Mech
Shimano XT Rear Mech
Shimano XT Cassette
Sram 1051 Chain
Shimano Saint Brakes
E13 TRS+ chainguide
Race Face Sixc Cranks
Race Face Sixc Bars
Thompson stem
Thompson stealth dropper
SDG Bell Air Ti Saddle
Well, I’m 6ft 3 but have quite short legs, so usually xl frames don’t have enough standover, and with a dropper I can’t always get the saddle low enough.
The shock linkage was custom to reduce the leverage ratio enough to allow me to run an air shock!
Fantastic frame & spec,love Bos forks.
If you do not have your Schwalbe Hans Dampf tires yet order them very soon,they are in really short supply.Just got mine from CRC.
Careful on the front mech – Ions come with a special clamp for a front derailleur included in the box, and if I remember right, it needs a SRAM front mech to fit it.
Didn’t know the front mech was sram specific. Fricking hope not I hate sram. I sent the lbs the frame details and the have the mech clamp so they can make it work…..
garage-dweller – Member
Lovely. Anyone care to explain the leverage ratio thing for me? I assume this is a rider weight thing and being ‘ not light’ I wondered why.
The longer the shock stroke, the lower pressure/sprint rate you need for a given weight.
So a 220lb rider on the regular 63mm shock might need 220psi in the shock, but on the longer shock might only need 180. Idea being that shocks work better when not so highly pressured.
